Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
Werkzeuge
Keine Werkzeuge angegeben.
  1. Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  3. Remove the battery.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
Abschluss
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 weitere Nutzer haben diese Anleitung absolviert.
Nick Loey
1.592 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Antwort
what is your return policy?
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 915
