Zum Hauptinhalt wechseln
HP dv5-1125nr Disk Drive Replacement
Was du brauchst
  1. HP dv5-1125nr Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: Schritt 3, Bild 1 von 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: Schritt 3, Bild 2 von 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: Schritt 4, Bild 1 von 3 HP dv5-1125nr Disk Drive Replacement: Schritt 4, Bild 2 von 3 HP dv5-1125nr Disk Drive Replacement: Schritt 4, Bild 3 von 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Abschluss
Nick Loey
1.676 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 732
