Einleitung
Replacing your optical drive is not a complex process. Follow this guide to learn how!
Was du brauchst
Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
Remove the CMOS panel cover.
The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
Using your hands, slide the remainder of the drive out of the computer.
