Diese Anleitung enthält neuere Änderungen. Wechsel zur neuesten unüberprüften Version.
Einleitung
Before replacing your hard drive make sure you have backed up all of your files and have an OS install disk on hand. Now you're ready to replace your hard drive!
Was du brauchst
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
Slide the hard drive out of the enclosure to complete the removal process.
3 weitere Personen haben diese Anleitung absolviert.
