Zum Hauptinhalt wechseln
HP dv5-1125nr RAM Replacement
Was du brauchst
  1. HP dv5-1125nr RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr RAM Replacement: Schritt 4, Bild 1 von 2 HP dv5-1125nr RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the RAM cover to reveal the module's underneath.
  5. HP dv5-1125nr RAM Replacement: Schritt 5, Bild 1 von 3 HP dv5-1125nr RAM Replacement: Schritt 5, Bild 2 von 3 HP dv5-1125nr RAM Replacement: Schritt 5, Bild 3 von 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Loey
1.676 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 942
