Zum Hauptinhalt wechseln
HP dv5-1125nr WLAN Card Replacement
Was du brauchst
  1. HP dv5-1125nr WLAN Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: Schritt 3, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: Schritt 5, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement: Schritt 5, Bild 2 von 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: Schritt 6, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: Schritt 7, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement: Schritt 7, Bild 2 von 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: Schritt 8, Bild 1 von 1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: Schritt 9, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement: Schritt 9, Bild 2 von 2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: Schritt 10, Bild 1 von 2 HP dv5-1125nr WLAN Card Replacement: Schritt 10, Bild 2 von 2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cory Mayer
879 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 9-15, Regan Spring 2014 Mitglied von Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,147
