Zum Hauptinhalt wechseln
HP eStation Zeen Motherboard Replacement
Was du brauchst
  1. HP eStation Zeen Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 HP eStation Zeen Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 HP eStation Zeen Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: Schritt 2, Bild 1 von 3 HP eStation Zeen Motherboard Replacement: Schritt 2, Bild 2 von 3 HP eStation Zeen Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: Schritt 7, Bild 1 von 2 HP eStation Zeen Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: Schritt 8, Bild 1 von 2 HP eStation Zeen Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: Schritt 9, Bild 1 von 2 HP eStation Zeen Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
dalton hale
503 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 16-4, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 553
