Einleitung
After following the troubleshooting procedures and the device still has no sound it may be time to replace the speaker.
Was du brauchst
Remove the rubber screw caps using a metal spudger.
Remove the two 6mm screw using a Phillips #0 screwdriver.
Unclip each side by inserting the plastic opening tool and slide it along the edges.
Remove the back panel by lifting the panel away from the device.
Fast fertig!
Abschluss
