Einleitung
This guide demonstrates how to remove and replace the volume buttons of an HP eStation Zeen in order to preserve the function of the device.
Was du brauchst
Use a metal spudger to remove the four screw caps.
Remove the four 6 mm screws using a Philips #0 screwdriver.
Insert a plastic opening tool and slide it along the edge to open the back panel.
Lift the back panel away from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
