Zum Hauptinhalt wechseln
HP g4 Heatsink/Fan (or Motherboard) Replacement
Was du brauchst
    1. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove bottom cover: Schritt 1, Bild 1 von 1
      • Flip the laptop bottom-upwards, and remove the two screws securing the bottom cover, and pull the bottom cover off.
      Frag FixBot
      Kommentar hinzufügen
    2. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove hard drive: Schritt 2, Bild 1 von 1
      • Simply pull the hard drive upwards and out, there are no screws. Be sure to disconnect the connector from the board.
      Frag FixBot
    3. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove the wireless card: Schritt 3, Bild 1 von 1
      • In order to remove the motherboard, you must remove the wireless card. Unscrew the single silver Philips screw holding the wireless card, pop each antenna off its connector with your fingernails, pull the wireless card out, and set it aside.
      Frag FixBot
    4. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove screws: Schritt 4, Bild 1 von 1
      • Remove the nine long Philips screws.
      • Remove the four medium-length screws from where the bottom cover was.
      • Remove the two short screws from where the hard drive was.
      Frag FixBot
    5. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove optical drive: Schritt 5, Bild 1 von 1
      • Simply slide out the optical drive, the screw holding it was removed in the last step.
      Frag FixBot
    6. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove keyboard: Schritt 6, Bild 1 von 1
      • Push the five keyboard clips towards the screen using a flathead screwdriver.
      • Don't pry too hard, or else you will damage the palmrest.
      • Once the keyboard is loose, release the locking connector for the keyboard, and pull the cable out.
      Frag FixBot
    7. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove palmrest cables: Schritt 7, Bild 1 von 1
      • Flip the laptop up, back to normal position, and open the screen.
      • Remove all cables indicated red in the picture. (There's no need to deal with the orange-marked one just yet.)
      Frag FixBot
    8. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove motherboard: Schritt 8, Bild 1 von 2 HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove motherboard: Schritt 8, Bild 2 von 2
      • Remove all marked cables from the motherboard.
      • The DC jack connector may require quite some pulling. Just pull it, it'll come out.
      • Also remove the single marked blue-painted screw.
      • The motherboard can now be lifted upwards.
      Frag FixBot
    9. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove heatsink/fan assembly from motherboard: Schritt 9, Bild 1 von 1
      • Pull upwards on the fan wires to remove the connector from the motherboard.
      • Remove the four screws from around the CPU socket.
      • At this point, you're done removing the heatsink/fan assembly from the motherboard. Continue if you want to remove dust from the heatsink, otherwise you may stop here.
      Frag FixBot
    10. HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove fan clip & screws: Schritt 10, Bild 1 von 3 HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove fan clip & screws: Schritt 10, Bild 2 von 3 HP g4 Heatsink/Fan (or Motherboard) Replacement, Remove fan clip & screws: Schritt 10, Bild 3 von 3
      • Bend the metal clip outwards.
      • Get out the Philips #0 bit, and remove the two very small Philips screws from the assembly.
      • Wiggle the fan out, separating it from the rest of the assembly.
      • You're done! Check out that dust in this g4 in the third picture.
      Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 66
Insgesamt: 1,724
