Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Slide the silver release tab up and simultaneously lift the cover up from the left side.
Next, use your plastic removal tool to separate the gray back from the black center piece.
For better results, start the separation at the corner piece.
Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
Next you will need to unlock and remove the ribbon cable
Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
Next you need to remove the wire off the bottom of the mother board
Make sure all these connections are properly disconnected before separation of the motherboard
Next use your plastic removal tool and separate the silver front case from the black frame.
Remove the 4 screws along the bottom of the faceplate
They are #00 Philips head screws
Ein weiterer Nutzer hat diese Anleitung absolviert.
