Zum Hauptinhalt wechseln
HP w2216h Control Buttons Replacement
Was du brauchst
  1. HP w2216h Control Buttons Replacement, Control Buttons: Schritt 1, Bild 1 von 1
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
    Frag FixBot
  2. HP w2216h Control Buttons Replacement: Schritt 2, Bild 1 von 2 HP w2216h Control Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
    Frag FixBot
  3. HP w2216h Control Buttons Replacement: Schritt 3, Bild 1 von 3 HP w2216h Control Buttons Replacement: Schritt 3, Bild 2 von 3 HP w2216h Control Buttons Replacement: Schritt 3, Bild 3 von 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
    Frag FixBot
  4. HP w2216h Control Buttons Replacement: Schritt 4, Bild 1 von 1
    • Lift the screen assembly from the plastic housing from the corners.
    Frag FixBot
  5. HP w2216h Control Buttons Replacement: Schritt 5, Bild 1 von 1
    • Remove the plastic buttons from the contacts
    Frag FixBot
  6. HP w2216h Control Buttons Replacement: Schritt 6, Bild 1 von 2 HP w2216h Control Buttons Replacement: Schritt 6, Bild 2 von 2
    • Remove the wire connecting the contacts to the screen assembly.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-1, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 60
Insgesamt: 740
