Zum Hauptinhalt wechseln
HP w2216h Power Supply Replacement
Was du brauchst
  1. HP w2216h Power Supply Replacement, Screen: Schritt 1, Bild 1 von 1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Power Supply Replacement: Schritt 2, Bild 1 von 2 HP w2216h Power Supply Replacement: Schritt 2, Bild 2 von 2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Power Supply Replacement: Schritt 3, Bild 1 von 3 HP w2216h Power Supply Replacement: Schritt 3, Bild 2 von 3 HP w2216h Power Supply Replacement: Schritt 3, Bild 3 von 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Power Supply Replacement: Schritt 4, Bild 1 von 3 HP w2216h Power Supply Replacement: Schritt 4, Bild 2 von 3 HP w2216h Power Supply Replacement: Schritt 4, Bild 3 von 3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Power Supply Replacement: Schritt 5, Bild 1 von 2 HP w2216h Power Supply Replacement: Schritt 5, Bild 2 von 2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Power Supply Replacement: Schritt 6, Bild 1 von 3 HP w2216h Power Supply Replacement: Schritt 6, Bild 2 von 3 HP w2216h Power Supply Replacement: Schritt 6, Bild 3 von 3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Power Supply Replacement: Schritt 7, Bild 1 von 3 HP w2216h Power Supply Replacement: Schritt 7, Bild 2 von 3 HP w2216h Power Supply Replacement: Schritt 7, Bild 3 von 3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Power Supply Replacement, Power Supply: Schritt 8, Bild 1 von 1
    • Monitor power supplies can be dangerous. Read ifixit's monitor safety guide before working with power supplies.
    • Remove the cables connecting the power supply to the display port.
  9. HP w2216h Power Supply Replacement: Schritt 9, Bild 1 von 1
    • Remove the four 8mm Phillips #000 head screws connecting the power supply to the screen assembly.
  10. HP w2216h Power Supply Replacement: Schritt 10, Bild 1 von 1
    • Lift the power supply vertically out of the screen assembly
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Branflakes222
399 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 1,169
