Was du brauchst
Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
Fast fertig!
Abschluss
