Zum Hauptinhalt wechseln
HP-Pavillion 500-424 PC Series CPU Fan Replacement
Was du brauchst
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: Schritt 1, Bild 1 von 2 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: Schritt 1, Bild 2 von 2
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 2, Bild 1 von 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 2, Bild 2 von 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 2, Bild 3 von 3
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 3, Bild 1 von 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 3, Bild 2 von 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: Schritt 3, Bild 3 von 3
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
Abschluss
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Pasco Hernando, Team S5-G73, Prince Fall 2018 Mitglied von Pasco Hernando, Team S5-G73, Prince Fall 2018
PHSC-PRINCE-F18S5G73
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 1,892
