Zum Hauptinhalt wechseln
HTC 10 Disassembly
Was du brauchst
Videoanleitungen
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.409 Reputation
378 Anleitungen geschrieben
7 Kommentare
Be VERY careful around the corners of the screen when removing the display. The LCD can be damaged easily if the card (or any other adhesive removing tool) is pushed too far. As you can see in this video as he pushes the card near the bottom right corner of the display, he is also messing with the LCD.
Joona Repo - Antwort
Hello,
Can you tell me which is the total track lenght of the rear camera? It seems to be shorter than the front camera, isn’t it?
Thank you Ivan
Ivan Perino - Antwort
at 5:14 part, what is the wire connected to? what if it breaks?
OTrizy - Antwort
Hey can you tell me where is the emmc chip ? Regards
Dekaj Armand - Antwort
Where is the antenna for wifi and bluetooth? After battary replacement my wifi and bluetooth stoped working.
Çağdaş Son - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 34
Insgesamt: 34,596
