Zum Hauptinhalt wechseln
HTC 7 Surround Camera Replacement
Was du brauchst
  1. HTC 7 Surround Camera Replacement, Back Case: Schritt 1, Bild 1 von 2 HTC 7 Surround Camera Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: Schritt 2, Bild 1 von 3 HTC 7 Surround Camera Replacement: Schritt 2, Bild 2 von 3 HTC 7 Surround Camera Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: Schritt 3, Bild 1 von 1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: Schritt 4, Bild 1 von 1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 164
