Einleitung
Use this guide to do a battery replacement on HTC Amaze. No tools are required for this guide and you can easily follow the steps to replace or remove a battery.
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Once you locate the battery, look for a notch below it.
Gently insert your fingernails into the notch.
Lift the battery out of its recess.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
