Was du brauchst
The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
