Zum Hauptinhalt wechseln
HTC Desire 510 Earpiece Replacement
Was du brauchst
Einführungsvideo
  1. HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: Schritt 1, Bild 1 von 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: Schritt 1, Bild 2 von 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: Schritt 1, Bild 3 von 3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: Schritt 2, Bild 1 von 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: Schritt 2, Bild 2 von 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: Schritt 2, Bild 3 von 3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: Schritt 3, Bild 1 von 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: Schritt 3, Bild 2 von 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: Schritt 3, Bild 3 von 3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: Schritt 4, Bild 1 von 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: Schritt 4, Bild 2 von 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: Schritt 4, Bild 3 von 3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Earpiece Replacement, EARPIECE: Schritt 5, Bild 1 von 1
    • The earpiece is in the upper part of the middle panel.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.182 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.521 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,515
