Zum Hauptinhalt wechseln
HTC Desire 610 Charging Port Replacement
Was du brauchst
  1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: Schritt 1, Bild 1 von 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: Schritt 1, Bild 2 von 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: Schritt 1, Bild 3 von 3
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Charging Port Replacement, Charging Port: Schritt 6, Bild 1 von 1
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  7. HTC Desire 610 Charging Port Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using a pair of tweezers, disconnect the antenna wire.
  8. HTC Desire 610 Charging Port Replacement: Schritt 8, Bild 1 von 3 HTC Desire 610 Charging Port Replacement: Schritt 8, Bild 2 von 3 HTC Desire 610 Charging Port Replacement: Schritt 8, Bild 3 von 3
    • Peel back the gray adhesive strip using the precision tweezers.
  9. HTC Desire 610 Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  10. HTC Desire 610 Charging Port Replacement: Schritt 10, Bild 1 von 3 HTC Desire 610 Charging Port Replacement: Schritt 10, Bild 2 von 3 HTC Desire 610 Charging Port Replacement: Schritt 10, Bild 3 von 3
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  11. HTC Desire 610 Charging Port Replacement: Schritt 11, Bild 1 von 3 HTC Desire 610 Charging Port Replacement: Schritt 11, Bild 2 von 3 HTC Desire 610 Charging Port Replacement: Schritt 11, Bild 3 von 3
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kaycee Hammond
273 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G1, Wilson Spring 2017 Mitglied von IUPUI, Team S1-G1, Wilson Spring 2017
IUPUI-WILSON-S17S1G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Super duper 5
Nizamcdk - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 1,234
