Einleitung
Has your HTC Desire 610 stopped charging and you know it's not a battery or charging cord issue? Follow these steps to replace a faulty charging port in an HTC Desire 610. In this guide you will learn how to take off the back, unscrew the circuit cover, and safely take out the charging port to replace with a new one.
Was du brauchst
Using a plastic opening tool, take off the back cover of the phone.
Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
