Was du brauchst
Insert an opening pick between the back cover and chassis, and pry around the perimeter until the back cover releases.
Remove the back cover.
Remove the "void" sticker over the screw near the top-right of the battery, and the larger one near bottom of the battery.
Use a Torx T5 screwdriver to remove the six screws.
Use a Phillips #000 screwdriver to remove the two screws.
Use an ESD safe tool to carefully "walk" the battery connector out of its port.
Use an opening tool to lift the battery up and out of its housing.
2 weitere Personen haben diese Anleitung absolviert.
