Zum Hauptinhalt wechseln
HTC Desire 626s Backplate Replacement
Was du brauchst
  1. HTC Desire 626s Backplate Replacement, Backplate: Schritt 1, Bild 1 von 3 HTC Desire 626s Backplate Replacement, Backplate: Schritt 1, Bild 2 von 3 HTC Desire 626s Backplate Replacement, Backplate: Schritt 1, Bild 3 von 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: Schritt 2, Bild 1 von 2 HTC Desire 626s Backplate Replacement: Schritt 2, Bild 2 von 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: Schritt 3, Bild 1 von 2 HTC Desire 626s Backplate Replacement: Schritt 3, Bild 2 von 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 263
