Einleitung
Capturing images is how people retain visible proof of memories being created. This guides purpose is to help the user replace a major key component in a cellular device that gives users the ability to see themselves.
Was du brauchst
Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
Using the T5 screwdriver, unscrew these four screws in order to remove the plastic casing.
Using the PH000 screw driver head, unscrew the one screw that is holding down the mother board. (This screw is located on the left side of the motherboard.)
Using a pair of tweezers, gently disconnect the battery wire from the motherboard.
Using a pair of tweezers, lift the white part of the connector and disconnect the camera from the motherboard.
Use a pair of tweezers to slide the camera out and remove the camera from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
