Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
  1. Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. Using the PH000 screwdriver head, unscrew the  screw that is holding down the motherboard. It is located on the left side of the motherboard.
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. Remove top speaker gently with a pair of tweezers.
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Edward Garcia
509 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 5-3, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,104
