Zum Hauptinhalt wechseln
HTC Desire 826 Back Camera Replacement
Was du brauchst
  1. HTC Desire 826 Back Camera Replacement, Battery: Schritt 1, Bild 1 von 3 HTC Desire 826 Back Camera Replacement, Battery: Schritt 1, Bild 2 von 3 HTC Desire 826 Back Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Back Camera Replacement: Schritt 2, Bild 1 von 3 HTC Desire 826 Back Camera Replacement: Schritt 2, Bild 2 von 3 HTC Desire 826 Back Camera Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Back Camera Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Back Camera Replacement: Schritt 4, Bild 1 von 2 HTC Desire 826 Back Camera Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Back Camera Replacement, Back Camera: Schritt 5, Bild 1 von 3 HTC Desire 826 Back Camera Replacement, Back Camera: Schritt 5, Bild 2 von 3 HTC Desire 826 Back Camera Replacement, Back Camera: Schritt 5, Bild 3 von 3
    • Use a T5 Torx screwdriver to remove the three 4.0 mm screws.
  6. HTC Desire 826 Back Camera Replacement: Schritt 6, Bild 1 von 1
    • Use the spudger to lift the black plastic covering.
  7. HTC Desire 826 Back Camera Replacement: Schritt 7, Bild 1 von 3 HTC Desire 826 Back Camera Replacement: Schritt 7, Bild 2 von 3 HTC Desire 826 Back Camera Replacement: Schritt 7, Bild 3 von 3
    Kaufen
    • Use the spudger to lift the green board. The back camera is attached on the side as shown.
    • Use the tweezers to disconnect and remove the camera.
Abschluss
Jordan Warnix
285 Reputation
2 Anleitungen geschrieben
University of Alabama, Team S1-G2, Bedsole Fall 2019 Mitglied von University of Alabama, Team S1-G2, Bedsole Fall 2019
UA-BEDSOLE-F19S1G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 222
