Einleitung
Follow this guide to replace your HTC Desire 826 front camera.
Was du brauchst
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
Remove the metal bracket with the tweezers.
Use the T5 screwdriver to remove the three 4.0 mm screws as shown.
Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
Use the tweezers to detach the cameras wire from the top motherboard
Then use the tweezers to remove the camera
