Einleitung
How to replace your screen to your HTC Desire 826.
Was du brauchst
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Remove the two 4.0 mm screws attaching the bottom plastic panel using a T5 screwdriver.
Remove the black plastic cover using a plastic spudger
Use the metal spudger to pry up the plastic cover pieces from the front of the phone
Pry up the edges of the screen using the metal spudger
Then use the suction cup to remove the screen from your device
Ein Kommentar
Après avoir fait le démontage de l'écran , le digital est devenu très dur et ne réagi pas automatiquement au toucher . Que dois-je faire ?
