Einleitung
Follow this guide to replace the battery in your HTC Desire
Was du brauchst
Insert flat end of spudger into slot on the top of phone to pry off the back plate.
Use flat edge of spudger to lift the bottom right corner of the battery.
Lift the battery out of the phone.
To reassemble your device, follow these instructions in reverse order. Make sure the the arrow on the battery is pointing to the bottom left when inserting a new one.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
