Einleitung
This will show reader how to dissemble the inside of a HTC Desire. It will teach readers how to replace the internal speaker of the phone.
Was du brauchst
Insert flat end of spudger into slot on the top of phone to pry off the back plate.
Use flat edge of spudger to lift the bottom right corner of the battery.
Lift the battery out of the phone.
Take out the upper, two 0.5 mm Torx screws with a Torx T5 bit.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
