Zum Hauptinhalt wechseln
HTC Desire V Button Assembly Replacement
Was du brauchst
  1. HTC Desire V Button Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 HTC Desire V Button Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 HTC Desire V Button Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: Schritt 2, Bild 1 von 3 HTC Desire V Button Assembly Replacement: Schritt 2, Bild 2 von 3 HTC Desire V Button Assembly Replacement: Schritt 2, Bild 3 von 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: Schritt 3, Bild 1 von 3 HTC Desire V Button Assembly Replacement, Midframe: Schritt 3, Bild 2 von 3 HTC Desire V Button Assembly Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: Schritt 4, Bild 1 von 3 HTC Desire V Button Assembly Replacement: Schritt 4, Bild 2 von 3 HTC Desire V Button Assembly Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: Schritt 5, Bild 1 von 2 HTC Desire V Button Assembly Replacement, Button Assembly: Schritt 5, Bild 2 von 2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: Schritt 6, Bild 1 von 2 HTC Desire V Button Assembly Replacement: Schritt 6, Bild 2 von 2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: Schritt 7, Bild 1 von 2 HTC Desire V Button Assembly Replacement: Schritt 7, Bild 2 von 2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
William McCusker
1.096 Reputation
9 Anleitungen geschrieben
Clemson, Team 14-3, Shirley Winter 2015 Mitglied von Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 316
