Einleitung
This guide will outline how to remove and replace the vibration motor of the HTC Desire V smartphone.
Was du brauchst
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Gently remove the motor from its housing in the phone’s chassis.
The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
