Zum Hauptinhalt wechseln
HTC Droid Eris Battery Replacement
Was du brauchst
  1. HTC Droid Eris Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Droid Eris Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Battery Replacement: Schritt 2, Bild 1 von 2 HTC Droid Eris Battery Replacement: Schritt 2, Bild 2 von 2
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
Abschluss
SUNY Cortland, Team 1-2, Getto Spring 2013 Mitglied von SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 754
