Einleitung
With this phone, the LCD and digitizer are removed together. These can then be separated by heating. If there is a discrepancy with the way images appear on your screen you may have a broken LCD. However, if you are unable to utilize the touchscreen interface then you may have a broken digitizer.
Was du brauchst
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
Remove the 4mm Torx screw holding the charging port to the phone.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
