Einleitung
In addition to the possibility that the battery may be the reason why your phone is not charging, the charging port may also need to be replaced or tightened if loose. Ensure that the delicate parts of the phone revealed in the replacement procedure.
Was du brauchst
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
Remove the 4mm Torx screw holding the charging port to the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
