Einleitung
Use this guide to remove or replace your current MicroSD card. The Droid Incredible supports a MicroSD card up to 32 GB.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone. Useful tip: a penny or dime works in a pinch if you can't use your thumbnail. Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. Remove the rear panel from the phone.
    • Remove the rear panel from the phone.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap. Lift the top of the battery up and remove the battery from the rear inner frame. Lift the top of the battery up and remove the battery from the rear inner frame.
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. Press the MicroSD card further into its slot until it clicks. Release the MicroSD card, and it will pop out slightly.
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  6. Pull the MicroSD card straight out of its slot. Pull the MicroSD card straight out of its slot.
    • Pull the MicroSD card straight out of its slot.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Andrew Optimus Goldberg
409.426 Reputation
412 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
108 Mitglieder
8.319 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,744
