Einleitung
Is your Droid Incredible not sounding so incredible? Use this guide to replace the rear speaker.
  1. Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone. Useful tip: a penny or dime works in a pinch if you can't use your thumbnail. Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. Remove the rear panel from the phone.
    • Remove the rear panel from the phone.
  3. Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap. Lift the top of the battery up and remove the battery from the rear inner frame. Lift the top of the battery up and remove the battery from the rear inner frame.
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. Press the MicroSD card further into its slot until it clicks. Release the MicroSD card, and it will pop out slightly.
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. Pull the MicroSD card straight out of its slot. Pull the MicroSD card straight out of its slot.
    • Pull the MicroSD card straight out of its slot.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Remove four T6 Torx screws securing the rear inner frame to the front case.
    • Remove four T6 Torx screws securing the rear inner frame to the front case.
  8. The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
    • The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
  9. Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver. Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
    • Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
    • Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
  10. Loosen the clips on the side next to the camera using the method described in the previous step. Loosen the clips on the side next to the camera using the method described in the previous step.
    • Loosen the clips on the side next to the camera using the method described in the previous step.
  11. Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others. Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
    • Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
  12. Use the same technique to loosen the clip on the top of the phone. You may need to gently lift the bottom of the rear inner frame to free this clip. You may need to gently lift the bottom of the rear inner frame to free this clip.
    • Use the same technique to loosen the clip on the top of the phone.
    • You may need to gently lift the bottom of the rear inner frame to free this clip.
  13. Remove the rear inner frame. Remove the rear inner frame.
    • Remove the rear inner frame.
  14. Pry the rear speaker out of its socket with a small flathead screwdriver. Pry the rear speaker out of its socket with a small flathead screwdriver.
    • Pry the rear speaker out of its socket with a small flathead screwdriver.
Abschluss
To reassemble your device, follow these instructions in reverse order. Note that the spring contacts on the rear speaker must face toward the outside of the device, to connect with the logic board.
Andrew Optimus Goldberg
406.117 Reputation
412 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
100 Mitglieder
7.962 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,081
