Zum Hauptinhalt wechseln
HTC EVO 4G Speaker Replacement
Was du brauchst
  1. HTC EVO 4G Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 HTC EVO 4G Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Speaker Replacement: Schritt 2, Bild 1 von 2 HTC EVO 4G Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Speaker Replacement: Schritt 3, Bild 1 von 1
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Speaker Replacement: Schritt 5, Bild 1 von 3 HTC EVO 4G Speaker Replacement: Schritt 5, Bild 2 von 3 HTC EVO 4G Speaker Replacement: Schritt 5, Bild 3 von 3
    • Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Speaker Replacement: Schritt 6, Bild 1 von 1
    • use plastic pic to gently pry our the speaker
    • be sure to have your replacement unit ready
Abschluss
Sage Jurado
1.128 Reputation
4 Anleitungen geschrieben
New Mexico State, Team 1-1, Easley Spring 2014 Mitglied von New Mexico State, Team 1-1, Easley Spring 2014
NMSU-EASLEY-S14S1G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 186
