Zum Hauptinhalt wechseln
HTC Excalibur Battery Replacement
Was du brauchst
  1. HTC Excalibur Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power the phone off. Remove the back cover of the Phone, exposing the battery.
    • Grasp the battery by the two indents on either side of it, near the bottom. Lift up, pulling the battery loose. Remove the battery completely.
  2. HTC Excalibur Battery Replacement: Schritt 2, Bild 1 von 1
    • Take the new battery and orient it correctly -- the arrow should be facing towards the camera lens, face up.
    • Insert the battery at an angle, pushing the battery in until it is aligned on the top edge. Push the rest of the battery in, snapping it into place.
    • Reattach the battery cover, and power up your phone.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ian Mitchell
142 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-27, Garner Spring 2011 Mitglied von Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,103
