Einleitung
This guide will help if you are having issues with the primary buttons sticking or not communicating with your device.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Apply pressure to the dark plastic casing and slide the casing downward, off of the phone. Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
  2. Fold the plastic flap open. Fold the plastic flap open.
    • Fold the plastic flap open.
  3. Pull on the red tab to slide the battery out. Take out the battery.
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
  6. Once the screws are removed from the plastic flap, the piece should easily come out.
    • Once the screws are removed from the plastic flap, the piece should easily come out.
  7. After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons. In order to remove the circuit board you must disconnect the labeled component.
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
  8. Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
Abschluss
Ryan Curtis
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 8-3, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-3, Leahy Fall 2014
USFT-LEAHY-F14S8G3
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 364
