Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the earpiece speaker in the HTC HD2. This is a fairly easy repair, once the rear cover is removed.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Carefully pull the rear cover from the back of the phone.
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. Lay the phone down on it's screen. Lift up on the lip and pull the battery from the phone.
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. Remove the four black 3.5mm T5 screws from the back of the phone. Remove the four black 3.5mm T5 screws from the back of the phone.
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. Disconnect the small speaker cable from its socket on the motherboard. Remove the earpiece speaker from the phone. Remove the earpiece speaker from the phone.
    • Disconnect the small speaker cable from its socket on the motherboard.
    • Remove the earpiece speaker from the phone.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nathan Puchalski
813 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-55, Amido Spring 2011 Mitglied von Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 4,832
