Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the midframe of your HTC HD2.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Carefully pull the rear cover from the back of the phone.
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. Lay the phone down on it's screen. Lift up on the lip and pull the battery from the phone.
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Remove the four black 3.5mm T5 screws from the back of the phone. Remove the four black 3.5mm T5 screws from the back of the phone.
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  5. Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Sam Luedloff
715 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 24-55, Amido Spring 2011 Mitglied von Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 8,726
