Einleitung
The vibrator is easy to find and remove after the housing has been taken off.
Ersatzteile
Keine Ersatzteile angegeben.
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Lay the phone down on it's screen.
Lift up on the lip and pull the battery from the phone.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
Set the phone down on its screen.
Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
Ein weiterer Nutzer hat diese Anleitung absolviert.
