Zum Hauptinhalt wechseln
Einleitung
A part that might fail after you drop your HTC Magic is the speaker. Here's how to replace it. You will need Torx T6 & T5 drivers , a screwdriver, & a iPod opening tool(s).
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open the phone by removing it's backcover (battery door) and the battery. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. Unscrew the six screws with a Torx T5 screwdriver.
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Remove the antenna (use the little gap at the top ). Remove the antenna (use the little gap at the top ).
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  5. The rear housing should look like the picture on the left. The speaker part is at the top. Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
Abschluss
LucasJV
717 Reputation
3 Anleitungen geschrieben
Verheij.co Mitglied von Verheij.co
Business
1 Mitglied
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 10,552
