Zum Hauptinhalt wechseln
HTC Maple 100 External Speaker Replacement
Was du brauchst
  1. HTC Maple 100 External Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 External Speaker Replacement: Schritt 2, Bild 1 von 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 External Speaker Replacement: Schritt 3, Bild 1 von 2 HTC Maple 100 External Speaker Replacement: Schritt 3, Bild 2 von 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 External Speaker Replacement, Back Panel: Schritt 4, Bild 1 von 2 HTC Maple 100 External Speaker Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 External Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 External Speaker Replacement: Schritt 6, Bild 1 von 3 HTC Maple 100 External Speaker Replacement: Schritt 6, Bild 2 von 3 HTC Maple 100 External Speaker Replacement: Schritt 6, Bild 3 von 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 External Speaker Replacement, External Speaker: Schritt 7, Bild 1 von 2 HTC Maple 100 External Speaker Replacement, External Speaker: Schritt 7, Bild 2 von 2
    • Using the plastic opening tool, pry the external speaker out of the back panel.
Abschluss
Alyssa Thompson
11 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-29, Maness Fall 2011 Mitglied von Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 844
