Einleitung
Be careful with the LCD screen. It is fragile.
  1. First remove the back cover of your phone to expose the battery.
    • First remove the back cover of your phone to expose the battery.
  2. Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
    • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
  3. Take the battery out When reassembling, make sure that the battery contacts match up.
    • Take the battery out
    • When reassembling, make sure that the battery contacts match up.
  4. Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
  5. Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
    • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
    • Use the plastic opening tool to pry the clips off
    • Insert the plastic opening tool along the seams at different points to it pry up
    • This may require a bit of force. The USB port cover may fall off in this step.
  8. Remove the one 3.3mm #00 screw. Remove the one 3.3mm #00 screw.
    • Remove the one 3.3mm #00 screw.
  9. Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  10. Peel off the yellow piece of tape from the phone Peel off the yellow piece of tape from the phone
    • Peel off the yellow piece of tape from the phone
  11. First flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers Pull on the ribbon cable gently with your fingers
    • First flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers
  12. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
    • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
  13. Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
    • Gently pull on the ribbon cable to separate the motherboard.
  14. Pry the LCD screen out using the plastic opening tool and remove it using your fingers. Pry the LCD screen out using the plastic opening tool and remove it using your fingers. Pry the LCD screen out using the plastic opening tool and remove it using your fingers.
    • Pry the LCD screen out using the plastic opening tool and remove it using your fingers.
Abschluss
Nick
6 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 20-29, Maness Fall 2011 Mitglied von Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 999
