Zum Hauptinhalt wechseln
HTC MyTouch 4G LCD Replacement
Was du brauchst
  1. HTC MyTouch 4G LCD Replacement, Flip Phone Over: Schritt 1, Bild 1 von 1
    • Flip your phone over and hold the phone with the back facing you.
  2. HTC MyTouch 4G LCD Replacement, Remove the back case.: Schritt 2, Bild 1 von 1
    • Place the prying tool into the notch at the bottom of the case and pull up to remove.
  3. HTC MyTouch 4G LCD Replacement, Remove the battery: Schritt 3, Bild 1 von 2 HTC MyTouch 4G LCD Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
  4. HTC MyTouch 4G LCD Replacement, Removing Screws: Schritt 4, Bild 1 von 1
    • Remove the two T5x5mm Screws with the T5 Torx Screw driver.
    • Remove the one Phillips screw with the Phillips #00 Screwdriver.
  5. HTC MyTouch 4G LCD Replacement, Removing back case.: Schritt 5, Bild 1 von 3 HTC MyTouch 4G LCD Replacement, Removing back case.: Schritt 5, Bild 2 von 3 HTC MyTouch 4G LCD Replacement, Removing back case.: Schritt 5, Bild 3 von 3
    • Use the plastic opening tools to remove the back case.
    • There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
    • Using the plastic opening tools, remove the Wifi antenna.
  6. HTC MyTouch 4G LCD Replacement, Removing four T5 Screws: Schritt 6, Bild 1 von 2 HTC MyTouch 4G LCD Replacement, Removing four T5 Screws: Schritt 6, Bild 2 von 2
    • There are three button ribbons on the phone that need to be pulled down off of the case.
    • With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
  7. HTC MyTouch 4G LCD Replacement: Schritt 7, Bild 1 von 3 HTC MyTouch 4G LCD Replacement: Schritt 7, Bild 2 von 3 HTC MyTouch 4G LCD Replacement: Schritt 7, Bild 3 von 3
    • After making sure the button ribbons are away from the frame, insert the plastic opening tool into the frame and remove it.
    • Remove two Philips screws holding the Motherboard in place.
  8. HTC MyTouch 4G LCD Replacement: Schritt 8, Bild 1 von 2 HTC MyTouch 4G LCD Replacement: Schritt 8, Bild 2 von 2
    • Three ribbon cables and the vibration motor need to be disconnected from the Motherboard.
    • Using the plastic opening tools, pull up on the power button ribbon to gently detach it.
    • Remove the vibration motor by gently pulling it off of the Motherboard.
  9. HTC MyTouch 4G LCD Replacement: Schritt 9, Bild 1 von 3 HTC MyTouch 4G LCD Replacement: Schritt 9, Bild 2 von 3 HTC MyTouch 4G LCD Replacement: Schritt 9, Bild 3 von 3
    • Remove the digitizer ribbon cable with the plastic opening tools.
    • Remove the LCD ribon cable from its connector.
    • It is now safe to release the Motherboard from the clips holding it in place. Start at the top clip of the phone and move your way around gently releasing each clip.
  10. HTC MyTouch 4G LCD Replacement: Schritt 10, Bild 1 von 3 HTC MyTouch 4G LCD Replacement: Schritt 10, Bild 2 von 3 HTC MyTouch 4G LCD Replacement: Schritt 10, Bild 3 von 3
    • Do not lift the Motherboard off the phone. The LCD Ribbon is still connected to it.
    • Lift the Motherboard towards the left to expose the LCD clamp connector.
    • Open the clamp connector of the LCD ribbon by carefully pulling it up with the plastic opening tools.
  11. HTC MyTouch 4G LCD Replacement: Schritt 11, Bild 1 von 1
    • The Motherboard is now removed.
  12. HTC MyTouch 4G LCD Replacement, LCD: Schritt 12, Bild 1 von 3 HTC MyTouch 4G LCD Replacement, LCD: Schritt 12, Bild 2 von 3 HTC MyTouch 4G LCD Replacement, LCD: Schritt 12, Bild 3 von 3
    • Put the LCD side of the phone facing upward.
    • Use the iOpener to heat and loosen the adhesive up that is holding the digitizer in place.
    • Move the plastic opening tools along the outside edge of the digitizer to loosen it more and remove.
  13. HTC MyTouch 4G LCD Replacement: Schritt 13, Bild 1 von 3 HTC MyTouch 4G LCD Replacement: Schritt 13, Bild 2 von 3 HTC MyTouch 4G LCD Replacement: Schritt 13, Bild 3 von 3
    • Do not take the digitizer fully off as it is still connected by the ribbon.
    • Use the iOpener tool to heat up the LCD adhesive.
    • Using the iOpener kit and the plastic opening tools again, remove the LCD. The LCD is now ready to be replaced. Make sure to have more adhesive that usually comes with the replacement to make sure the LCD and digitizer will be secure.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
leo
334 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 16-5, Watkins Spring 2014 Mitglied von USF Tampa, Team 16-5, Watkins Spring 2014
USFT-WATKINS-S14S16G5
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 374
