Einleitung
Not able to listen to your favorite band on Spotify? Get back to rocking out with this guide.
Was du brauchst
Power off the device.
Locate the SD Card/SIM Card cover flap on the left side of the device.
Upon opening the cover flap you will find slots for SD Card and the SIM Card. Carefully remove these items if your device has them and set them aside.
Lift on the back cover to begin the removal process. Continue removing the back cover by working along the edge. Once removed set aside the back cover.
Remove the five 3.5mm T4 Torx Screws.
Remove the two 4.5mm #00 Phillips screws.
Place a plastic opening tool along the seam of the front plate and back plate. Run the opening tool along the seam while prying slightly in order to pop the plastic clips away from the front plate.
Once one or two clips have popped away you may begin to use your free hand to apply additional pressure while continuing to apply prying pressure as well with the opening tool.
Continue working your way around the seam between the two parts and eventually you will be able to separate the entirety of the backplate revealing the internals of the device.
Note the position of the 3.5mm Headphone Jack.
And the connector to the main board for the jack.
Grab the edge of the blue tape and pull away from the white connector. Set the tape aside as you will need it for the replacement.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
