Einleitung
Bring your device back from the dead after a failed battery sends it to an early grave.
Was du brauchst
Power off the device.
Locate the SD Card/SIM Card cover flap on the left side of the device.
Upon opening the cover flap you will find slots for SD Card and the SIM Card. Carefully remove these items if your device has them and set them aside.
Lift on the back cover to begin the removal process. Continue removing the back cover by working along the edge. Once removed set aside the back cover.
Remove the five 3.5mm T4 Torx Screws.
Remove the two 4.5mm #00 Phillips screws.
Place a plastic opening tool along the seam of the front plate and back plate. Run the opening tool along the seam while prying slightly in order to pop the plastic clips away from the front plate.
Once one or two clips have popped away you may begin to use your free hand to apply additional pressure while continuing to apply prying pressure as well with the opening tool.
Continue working your way around the seam between the two parts and eventually you will be able to separate the entirety of the backplate revealing the internals of the device.
Place the plastic opening tool to the side of the battery and work underneath the battery. Slowly and gently pry the battery away from the device removing the battery from the adhesive underneath.
After breaking away one side of the battery from the adhesive strips you can take advantage of the additional leverage by using your hand to break free from the adhesive on the opposite side.
After prying the battery free from the device the connector can be removed by pulling directly up away from the device.
Ein Kommentar
So I had this phone stuck in my closet in like 2 years or so. Water got into the micro-USB port and the whole phone just started to like reboot itself over and over. I pried the battery out of it and I need to look for both replacements. So I need to replace the micro-USB board or is there more to the problem? Please help!
